Dallas
- cleveland, oh
jpfreak said:Recalibrating the speedometer is done through a gear which connects to the transfer case (or transmission, I don't remember). Gears are available for every common tire size/gearing combination. It is not limited to the kit itself.
Don't quote me on anything, but I thought around 95 the xj switched from a mechanical cable and gear in the transfer case to an electronic sensor. I'm not sure but check out the description of the teraflex ESS SYE.
http://www.4wd.com/mudmag/spotlight.asp
Does that mean that as it is the speedo can be recalibrated?
