Chris S
- Vernon, BC, Canada
Ray H said:No. Ive got an Off Road base and its not at all what Im talking about. All the off road base does is spread the weight out so it doesnt sink. Im talking about a base that holds the bar vertical so it doesnt have a tendency to wobble or fall to side or front and back with the vehicle supported. A base with a larger footprint than the regular base (similar to the off road base) but that is braced and holds the bar tight enough that it becomes an integral part of the bar so the bar doesnt tend to tip over to the side with a load on it..
I get what you mean. if the base held the bottom three inches or so of the bar and used two pins instead of one it would be much more stable. I could also use a delrin sleeve around the bar so it is held tight and never rusts to the base.
