JJacobs
- Fort Collins CO
Tire tosser, good one. Yeah, I used to do a lot of tires.
I wish I could just cut'n paste this whole TSB but that'd be a no-no- maybe someone can find a link to it online. Ford TSB 07-10-10, titled Steering Wheel Oscillation is a good one. It deals with shimmy on coil sprung, solid axle trucks. Key points are fastener torque, damper replacement and caster reduction. We have also found that the track bar lower ball joint in the axle is a big player, when they get loose shimmy starts out mild until the damper fails, then it gets nasty, both are typically replaced at the same time. I know, it's for Fords but the same principles apply.
I've seen a couple XJ's where literally nothing was wrong but they'd wobble. Every single piece fit tight, excellent condition, no cracks, move the caster around, throw as many dampers as you want on it, still wouldn't help. Change the wheels to a little different offset- problem solved. Then there's others that are out of balance, loose balljoints, track bar and everything else without a hint of shimmy. XJ's can be downright evil when they want to be, that's why I don't recommend leaving off a part that may be essential.
