***WARN xd9000i winch with synthetic rope***
JESSE A
SIMI VALLEY, CA
I have a warn xd9000i winch for sale works great I can show you when you arrive to look at it if you like, also come with a 75 foot masterpull synthetic rope, and a masterpull rash gaurd to protect the rope. Also a remote and will include the original cable.
Asking 850.00 OBO
best way for contacting me is email
[email protected]
Located in simi valley ca
Little info
Part Numbers: 27550
Winch Model: XD9000i
Rated Line Pull: 9,000 lbs. (4080 kgs) single-line
Motor: Series Wound 12V 4.6 hp
Electrical controls: Solenoid
Remote Control: Remote switch, 12' (3.7m) lead
Geartrain: 3-Stage Planetary
Gear ratio: 156:1
Clutch (freespooling): Sliding Ring Gear
Brake: Automatic Direct Drive Cone
Drum diameter/Length: 2.5" /9.0" (6.4cm/23cm)
Weight: 85 lbs. (38.5kgs.)
Wire rope: 125', 5/16" dia. (38m, 8mm)
Fairlead: Roller
Recommended Battery: 650 CCA minimum for winching
Battery leads: 2 gauge, 72" (1.83m)
Finish: Argent Gray Powder Coat
