I purchased this synthetic rope, spooled it on, then....not long thereafter, found that I had another line, so despooled it, and installed the other.
Thus, other than a careful spool-on/despool, it is quite unused.
I measured it, to confirm length, and it is 99+'.
This one: https://www.ebay.com/itm/Gray-Synth...h=item4670cd1adb:g:hZwAAOSwBP9biLZh:rk:7:pf:0
As you will note in the photos, I did epoxy impregnate the end, and reduced it to fit the retention tunnel in the winch spool. You can easily add a crimped tube section, etc., to suit your mount. - And you may well need to reduce the length, anyway, to fit your unit.
MY photos viewable here:
https://www.northeastshooters.com/xen/threads/99-dyneema-synthetic-winch-rope-3-8-with-hook.366352/
$49.
Located in Foxboro, MA, and I can usually accommodate a visit most anytime.
$49.
