rockwerks
- Chito Beach Resort, WA
GusDaDog said:well my butt of the truck is also low which is something I've been told to fix ASAP and see if it helps. My rear is 3" lower than my front because I installed 2.5" lift spacers in front and extended shackles in back but the rear lift total was minimal to the front. I have a set of 3" blocks I still need to install to level it off but I am having trouble finding U bolts for a Dana 35.
Also ordered a kit to reinstall my swaybar with new bushings.
Then what?
Oh, and i CAN get over 55mph on a smooth as glass road, it is bumps, even minor ones that trigger the DW....
then its not wheel balance LOL and thanks for the further info. I would check for bad ball joints, its easy to do jsut jack up the truck one front wheel at a time so it is about 1/8" off the ground, use a block and pry far on teh front f teh tire to lift up on the tire/wheel and look for play in the ball joints, and it can be just one bad joint too. ya just gotta watch for any play
Any custom spring shop will have or can make the u bolts for ya.
