ren
- frenchburg, ky
When I said to use the weather strip adhesive, I said also to make sure to clean everything well. This how you get the stuff to hold for a long time. As a point in the case, I have not had a leak in over 2 years while gluing the covers on, but also as I said, good luck getting the sucker to let go when you have to take the cover back off. I do not believe that the weatherstrip adhesive is actually an RTV, which is a Room Temp. Vulcanizing compound, as much as it is more of an actual glue.
