JeepZJlover
- Marion, IA
Does anybody know bout this trick if so what's the part # what kinda benefit is it? Is it a direct fit ect? Thanks for the help guys
Note from DJ
Post # 9
Caution... Don't get the severe duty clutch from the "max-cooling" package... It won't fit. (I TRIED) You might be able to do it if you remove the radiator to bolt it up, but that’s a lot of work, and it would be so close to the rad that it would block more air than it is pulling. Plus, if you break a motor mount, or if your motor flexes at all, it is going to hit the fins. You want the HD that is only on the 97-98 ZJ WITHOUT max cooling!
When trolling the junkyard, how do you determine if it is max cooling or not?
For $48 new and the high failure rate of fan clutches, why bother with the JY?
