Oil Town XJ
- Edmonton, AB
*edit there 360/80 12" short bodies, will that be to stiff?
How hard is it to re-valve 7100's? it looks like I will be going with those for the front, but the guy has no idea what the valving is
Yeah, lots of good info. All 4 of my RE shocks are bad so I'm looking to buy new shocks coming up in the next month or two. I'd heard about the problems with FOAs, but also heard that they had supposedly fixed the problems as well. Anybody else heard anything? I figure a set of Bilstein 5150s at least for me, maybe going with remote reservoirs. Between me and my brother in law is a lot of open desert and I'd like to be able to take the back way across the desert faster than 15-20 mph.
That's completely and solely based on valving and nothing else.
Well, as you found out, shocks don't last forever. Thats why you should pick up (at least) 7100's so you can rebuild them. Last shocks you will ever have to buy. Just rebuild as needed.
The thing with cutomer service is you have to NEED to use it to find out if it's good. FOA customers HAVE to use customer service. I'd rather never know if Bilsteins customer service is good (although I know there tech guys service is hard to beat).
changing valving is pretty simple, no need to send them in as if you are a stickler, chances are you will be doing it more than once. Either way you are going to be sacrificing something with the angle(and lack of space) no matter what valving you run.Im going to be running Cross's hoop in about a month. But Im going to add a mounting hole between stock and there first hole. But if you are going to do a hoop buy a revalvable shock and be sure to send it in to be valved stiff with a good sized flutter stack or you will hate the crossover shock setup..reverse progression..very hard landing from a fully drooped suspension and get way soft by the time the shock if fully collapsed
Yeah I could do the valving but when it came to doing the flutter stack it gets complicated and since I didnt want to do it more than once I sent them to DSM because sonny said he deals with it all the time and could more than likely get it good to go the first try
That's what I'm thinking about. I'm totally new to this JeepSpeed thing so I have no idea. Basically I was thinking of running a shock hoop that doesn't go into the floor like that shock hoop from T&J that was posted, but people have said that it wouldn't be good for valving and whatnot.there any strong way to go through the floor with out having a bar go across? i need the trunk space for storage.... thanks.
