wheeling365
Both pics of the tread seperating are because there is air getting in between the cap and tire carcass. When they inspect and grind off the old tread they also usually check for holes thru the belt pack with high voltage electricity. Any places where the electricity makes it thru they mark and then are suppose to patch. Its very possible that they missed a patch or its not installed correctly.
When you dismount that tire I'd look inside for patches or other repairs. Also if the bead is torn or damaged it can allow air to travel up the sidewall and cause the same problem.
