trans controller
#1(25A) - aux power outlet
#2(25A) - cigar lighter
#3(10A) - left headlamp, fog lamp relay
#4(10A) - left headlamp
#5(10A) - right headlamp, daytime running lamp module
#6(5A) - trans slector switch illumination, transfer case switch illumination, instrument cluster, radio, rear wiper, A/C-heater control, rear window defogger, front fog lamp switch, and extended idle switch(police pkg)
#7(10A) - left marker lamps/turn signals, fog lamp relay, fog lamp switch, trailer tow connector, license lamp, left tail/stop lamp
#8 - spare (switched circuit - start/run)
#9(10A) - compass, sentry key immobilizer module, headlamp delay module, instrument cluster
#10(15A) - back-up lamp switch, transmission range sensor(4.0L A/T), daytime running lamp module, duty cycle evap/purge solenoid(gas), radiator fan relay, A/C compressor clutch relay, oxygen sensors
#11(20A) - powertrain control module, transmission control module, automatic shutdown relay, fuel pump relay
#12(10A) - combination flasher, instrument cluster
#13 - spare (not switched - connected directly to battery)
#14(10A) - power mirrors, rear window defogger switch
#15(25A) - passenger power lock/window switch
#16(10A) - right headlight
#17(15A) - radio
#18(10A) - heated seats, driver power lock/window switch, power mirror switch
#19(10A) - clutch interlock switch and switch jumper, engine starter motor relay
#20(15A) - trailer tow connector, trailer tow left/right turn relays
#21(15A) - horn relay, horn switch, horns, overhead module, clockspring
#22(20A) - rear wiper/washer switch, rear wiper motor
#23(10A) - right front park/turn signals/side marker lamps, right tail/stop lamp
#24 - spare (switched circuit - run only)
#25(15A) - blower motor relay, blend door actuator, shift lock solenoid, extended idle(police pkg), A/C-heater control, controller anti-lock brake and relay
#26(10A) - airbag control module
#27(10A) - airbag control module
#28(25A) - power lock/window switches
#29(25A) - power seat switches, heated seat relay
#30(20A) - wipe/wash switch, front wiper motor
