98cherokeedriver
- HI
OK, so I just finished up my WJ brake swap and I'm moving on to my next step. My current set, stock steering with TNT trackbar bracket, has some clearance issues. The bracket locates the trackbar too far forward, directly over the tie-rod. I'm only at two inches of lift, and have no plans to go any higher, only larger tires and wider axles, but that's much later. Anyways, I'm looking for a double sheer bracket that will solve this problem and work with my trackbar - Procomp with 3/4" narrow JJ with a 5/8 through hole. I'm thinking the RE bracket will work perfect, but seeing how I'm in the 50th state and everything is mail-order, expensive to ship, and hard to return, I just wanted to make sure, so I'm not getting a fourth bracket down the road :banghead:
If the RE bracket will work, would the brace be compatible with my lift height?
