My trackbar is to the point where I don't want to drive it out of fear that the joint is going to fail... It has enough play that you can turn the wheel from 10-2 while the jeep is off and it won't move the wheels.
I got the lower passenger side out without much trouble, The pin in the castle nut was spun so both ends were against the walls of the bracket, but managed to finally get it out.
Now when I turn the nut, the entire bolt spins with it. Tried PB Blaster, nothing. I thought of trying to cut the bolt between the joint and the bracket, but was told the hardened steel will just eat my cut-off wheels and not to even attempt it.
I'm sort of at a loss. Can't weld a nut, can't cut it off... Any ideas?
