lawsoncl
- North Idaho
Due to your job, I think you may be a bit more anal about calibrated equipment than most shop mechanics or the average shade-tree mechanic would be. Most people don't need a high precision/accuracy torque wrenches and are fine with medium quality (not the low end HF junk). On the other hand, it makes lots of sense to periodically check your tools to make sure they are in the ballpark. Personally, I'm not overly worried about the absolute accuracy of my own torque wrenches. I'm be happy if they are within 10% for most applications. Most torque specs have a 10% tolerance anyway and as pointed out earlier, a given fastener torque doesn't ensure a specific bolt tension due to variations in the bolt conditions. I think what's more important in many cases, such as tightening lugs or head bolts, is consistency. Odd fact, but in the absence of a proper torque wrench, most people over-tighten bolts.artsifrtsi said:Oh, yeah, Montanaman... if you'd read my first post you would have read into the fact that I work in a cal shop... an NIST traceable lab to be exact. I calibrate everything from physical/ dimentional to microwave equipment.
Yeah, meybe your method would be good for a wrench to use in an emergency, but for a rebuild or anything that is done other that to get back home, properly cal'd equipment is all that should be used.
