Paul S
NAXJA Member #103
- Woodland Hills, CA
The FT kit worked quite well, why the change?
Paul
Paul
Paul S said:The FT kit worked quite well, why the change?
Paul
Mike L said:He didn't like the loss of ground clearance by mounting the arm under the frame rail.
-Mike
Paul
David Taylor said:I see you lost the old front bumper :thumbup:
bj-666 said:just looking over your pics, what do you think about extending the drivers side UCA bracked back so it is helping resist bending of the arm in the bent area
Capt. Nemo said:I can't move the UCA bracket back any further on the axle end because the control arm is as short as it can go. I don't see the angle on the arm as a weak point or problem.
xjnation said:I moved the mounting points on the upper arms taller about 2" and the loer mounts in about 1/2"
bj-666 said:I ment the connection between the UCA and the LCA at the bend in the LCA. and not to move the bracket but to just lengthen it so it supports the bend in the LCA.
