ty20404
- Raleigh/Charlotte, NC
I've got a 2000 XJ with a 3" Budget boost. So pretty much, I've only netted 3". I know with a full spring kit from manuf. you can fit 31s, but typically you net between 3.5 and 4.0 inches on a 3.5" kit. So basically what I'm asking is:
Can I fit 31x10.5 Dueler A/T Revos with only 3 net inches of lift...?
And I'm not going to trim, possibly the inside of the fenderwell, but not the stock flares. I don't do any extreme off roading so cramming shouldnt be too much of an issue.
I was thinking of running 15x8 steelies on 4.75" of backspacing. Will that combo work on 3" of lift?
Or should I go with 15x7?
Currently I'm running 15x8 Jeep Canyons on 5.5" BS but I want to kick the tires out more, but not too much, and I dont want to rub the fenders.
If 31s arent possible, what wheel size should I run on 30"x9.5"?
Current setup: 3" BB, Jeep Canyon 15x8 5.5" BS, 30x9.5 BFG A/T KO
