Jeepcrush4
- Flushing new York
Lol, for that price it better come with 2 virgins,lol. Thanks, I just may go this route.
Running 33's on my '89 with 4.5" lift for over 3 years now. No t.c. drop and no s.y.e. I just put on the lift one day and started to drive it with no problems. I go offroad a lot but nothing too extreme and have had no problems.
And you have a different set up than the OP....
Everything changes after 96'
When i lifted mine i replaced the trans. Tcase, and Motor from a 96 2 door
the drive shaft was from the 2 door as well.
I have no SYE and little to no vibrations.
2dr or 4dr does not matter, they are both the same length.
Well the shafts looked different, instead on the shaft going into the tail shaft of the Tcase, It stuck out I had never seen this before.
Im sure there the same length,
It was just weird to see it not go into the Tcase.
Most of the peeps here run Advanced Adapters SYE and Tom Woods D/S.
I bought mine from here:
http://www.4x4groupbuy.com/store/ad...or-drive-shaft-p-115.html?manufacturers_id=12
Hmmmm, lucky you, they are on sale for $30 off.....
theres more to it then just vibs. if your out on the trail and you brake your rear axle shaft and need to remove the rear dirve line. with the slip yoke you will loose most of your fluid out the housing with the sye you can drive out in fwdMuddButt, or anyone else; why the Advanced Adapters? Tom Woods and others sell a super short sye. I realize that this is probably more for wranglers, but wouldn't this give better driveline angles on a xj too? I am asking not suggesting.
I have been a guy who dropped my tc and have been fine. However with going up in lift it is time to rip off the bandaid and do what is best for my jeep. I believe it is 4wd and suv who recently said that "a sye should be done on any jeep for trail prep." Even though I don't have vibes on my '01 I don't want my driveshaft to fall out on the trail.
Let me know what you guys think on my question, I will be ordering my sye this week and after having a bad experience elsewhere will probably order straight from Tom Woods.
BS01
