rstarch345
- Where ever I can wheel
Wow! Someone that actually understands the importance and need of a rear sway bar...... I don't think you really need anything heavier than stock.bjoehandley said:I've wondered about that myself, I was wondering if I could get away with all Urethane (sp?) in the back and maybe fresh rubber or a fresh rubber/urethane mix on the front.
I run my street tires at 36PSI as well and hook my rear sway bar up when towing. I find that with 5" of lift and towing a 25' trailer, it helps tremendously in keeping the tail from wagging the dog.
Definately get some front urathane bushings, especially the ones that you can grease. It makes the front more firm and the grease keeps them quite while providing smooth movement.
The rear, I haven't really found any direct replacement urathane bushings for, so I took an extra set and using an exacto knife and dremmil, made an excellent fitting set.
