Anyone know where I can find a damn tstat that has the hole in the top of it. Kragen, Autozone and Pepboys only have them with out the hole in the top.
:doh: not to high jack your thread,but I am going to ... is it nessecary to have a t-stat with a hole in it? I installed one from napa in my 99 without a hole and have had zero issues. End hi-jack:gag:
It's not 100% needed. It just helps to burp the system. If you check the coolant level every few days after you have installed the thermostat you should be fine. If it's been a week of driving and the coolant level is fine, I would say you are OK.
