Reader
- Neophyte to working on cars,in NJ/PA
I like the suggestion of upgrading the cooling system. Radiator, Transmission Cooler,..... But I seem to be stuck on the Thermostat.
The Jeep Horizons cooling upgrade recommendations suggested a 180-degree Hi Flow Thermostat with a Hi Flow Housing.
However, with the 2000, based on forum advice, I will probably go with a 195 degree OEM or Stant Thermostat.
Do I still go with a Hi Flow Housing or just get the housing made for the specific thermostat?
Does the Hi Flow Housing provide a separate advantage compatible with an OEM thermostat?
Thank you
Thank you
