C85D4x4
NAXJA Member #1311
- Ohio, Brecksville
Thanks man!!!
Driveshaft u-joint is 153x.WobblesXJ said:Anyone know the spicer part number for the driveshaft u-joints? I search but I guess I couldn't come up with the right combo of words.
xjohnnyc said:Driveshaft u-joint is 153x.
Isn't it true that you shouldn't run the CTM and OX u-joints with stock axle shafts? This would make the shafts the weak link. And it's easier and cheaper to replace a busted u-joint than to replace a busted shaft. I've heard that these uber-joints should only be used with aftermarket alloy shafts.
OneTonXJ said:I would buy the Longfield joints though as I feel they are actually worth it.
