ECKSJAY said:Hey John, after my old rear shocks being on for years with that setup, I finally started getting a clunk from worn bushings. I knew it was binding up when I'd flex because of the bushing orientation, but you're right about street performance. Doesn't really matter there. The guy before you explained the reason for the orientation very well. One 'free'-ish fix for using that swaybar bracket on the top is to find a set of TJ lower brackets that have been cut off the axle tube. Those will rotate the lower mount 90* as well as move them UP (if you desire).
I changed my bushings every couple of years anyway so I've never really had any issues.
I really like the TJ idea. For those that are worried about this it would be a great solution.
