mrtosh said:
Yup, changed it when i bought it last weekend. Also checked it yesterday when i did the waterpump and the coolant sensor. Guess I never thought of the radiator cap..... Would that cause the temp to fluctuate like that? Also @what temp does the OEM electric fan kick on? On my '89 XJ it comes on around 215-220..also, I don't know if this will matter, but after playing w/the jeep some, I noticed that when i first started the jeep and turned it to a/c the elec. fan would kick on, then turn off. Even if i turned it to a/c it wouldn't come on. What do you think?
I have seen small leaks from bad radiator caps, hose connections and tiny radiator leaks all make the temperature cycle like that. The size and duration of the leak affects the temperature range seen on the gauge.
I read recently that the electric fan should come on and run while the A/C compressor is running, and turn off when the A/C compressor is off. Not sure what years that was for, may be all of them, but not sure.
The electric fan cycles on/off with the A/C clutch. It is probably too cold for the A/C to stay ingaged right now. But if the A/C clutch is engaged and the cooling fan is not running, then there may be a wiring problem.
There is also a sperate thermal switch control in the radiator itself that cycles the electric fan on temperature. Most everyone in the forum says theirs cycle on at about 220 F, but the Haynes manual, or something I was re-reading yesteday says it should come on at about 190 to 195 F.
I have raised the question in this forum recently about calibration, error and accuracy in the temperature gauges, but I did not really get an answer. I think the old timers here realise that all the Gauges tend to lie (as they call it) a lot, and at different times and they have probably tired of discussing it and learned to just deal with it.
I bought a $20 infrared hand held sensor at Harbour Tools 2 weeks ago and I have been sampling the temperaure at various spots under the hood (not just the coolant temperatures) ever since to get closer, more precise values. I have confirmed that the temperature is very non-linear on the Jeep gauge, and with only three temperatures listed on the gauge (as I recall) anything in between those is a huge guess! Even the labeled values maybe off a good bit.
At some point it takes a certified ASTM thermometer to check all the gauge readings ( even the infrared ones I am getting) to see how accurate and precise they are. At least with the infrared one I have now I get measurements in 1 degree F increments. What I thought was 130 F on my gauge seems to be closer to 160 F.
