goodwilljeeper
- Pleasanton CA
Alright,
so recently i installed the currie steering and synergy ball joints and a newer used steering box. heres some questions for my problemS.
1.)
I took it to 4 wheel parts to be aligned because it pulls to the right a TAD BIT. not to much but just enough. they said that my passenger side is bent at the c because my camber is off and i would need a offset ball joint to possibly solve the problem. (driver side is good) so should i switch everything over to my other axle housing and hope that one isn't bent as well, or are synergy ball joints so tuff that the bad camber won't wear them down any faster. or any other suggestions. REMINDER: this is my DD.
2.)
i have a steering leak. so first its easier to turn right then left i think because of the camber but i could be wrong. also i had a leak in the hose but a new hose clamp solved that problem, now i have another leak in the box but i think its actually the box itself is leaking. is that possible? because if it is ill switch back to my old box that has a lot of play in the sector shaft.
i need some expert / outside of my head voices
thanks guys.
1.)
2.)
thanks guys.
