On my 2000, the tb bore is 60mm with a 58mm taper on the bottom.
You can get rid of the taper for a little extra oomph I have heard (I went straight to the 62mm)
If you want a 62mm, you either have to bore your current one & get a 62mm butterfly or buy an "aftermarket" tb.
HTH
