Thayer said:So I'm bored and decided to do some math....
I heard of people draining the pan, refilling it, driving for a few days, draining the pan, refilling it, driving for a few days....etc....repeating this cycle until they go through a whole case. I guess they don't want to tap into the lines and don't want to pay for a tranny flush, but want to get all the fluid replaced.
The problerm is that you get less and less of the old fluid out of the tranny everytime you repeat the process. I think the FSM says an empty tranny takes 8.45 qts and assumimg each pan drain gets 4 qts out, here goes the math:
First change gets 47% of the old fluid out (4/8.45).
Second change gets you out 69% of the old fluid (0.473+0.473^2).
Third time is 80% (0.473+0.473^2+0.473^3).
Forth time is 85%.
Fifth is 87%.
Sixth is 88%.
Pointless to do anymore change at this point.
So going through a case (12 qts = 3 changes) gets out 80% of the fluid, which is probably fine. I was just thinking about this and wondering about the math.
Tap in to the lines and you use 12 qts and 100% new fluid.
