5-90
- Hammerspace
87manche said:unplugging the sync sensor should have made it worse than before.
if there wasn't any change then it seems to me that the sync sensor wasn't doing it's job in the first place.
Concur. It would be the first one I've heard of failing, but it's a possibility.
If you disconnect a sensor, and it doesn't change anything, the sensor was shot to begin with - you'll end up replacing.
To replace the SYNC sensor, you need to pull the distributor. There's a roll pin that holds the gear on - drive it out, pull the gear off the bottom, and pull the shaft out the top. There are, I believe, two screws that hold the SYNC sensor down - remove those, change the sensor, and replace.
NOTE - make a "match mark" on the dizzy gear and shaft. Also:
When you remove the cap, make two marks where the rotor is pointing. Pull the dizzy, DO NOT move the rotor, and make a SINGLE mark where the rotor points after you get the thing out.
When you put it back in, make sure the gear is lined up with the match-mark on the shaft, align the rotor with the SINGLE mark you made, and install. Make sure the rotor lines up with the DOUBLE mark you made after it's fully seated... (Can you tell I've pulled a few distributors before?)
I find a Sharpie pen good for the rotor marks, and use a scribe for the gear marks. Reason for the Sharpie up top? If I ever have to pull the dizzy again, it's a cinch that the rotor won't be in the same place, and I can't be arsed with turning the engine - easier to sand the marks off and make new ones...
5-90
