I think you read me wrong. There are lots of things that can wrong that will make the motor require longing cranking time before it actually starts. But far less things will make the starter crank weaker or NOT at all.
So, it really doesn't matter how long it takes to crank to get the motor to start, that could be caused by dozen of things other than cables. If the starter is cranking the motor strong and reliably for the expected amount of time, then its unlikely there is something wrong with the starter motor/charging system, including the battery cables. It doesn't hurt to check, be careful, the current from the battery can heat things up fast enough and hot enough to easily burn you. BUT, I think your barking up the wrong tree here, if its cranks strong, but takes to long to start, you need to be looking at ignition and/or fuel, even sensors, NOT battery cables.
