Thanks... I need to get this figured out as I really like the LEDs.
I noticed that when I don't have my parking lights or headlights turned on, the new LED breake/tail lights flash when the OE blinkers are installed now. The Left blinker is flashing like normal and the Right brake/LED flashes with it and visa-versa. If I have my parking lights on or full-on headlights turned on the blinkers work as they should and I don't get the extra flashing (I'd assume because the tail light LEDs are already on).
If I can get the electronic/flasher relay deal figured out I'll install the LED's in the turn signals as well.
Now time to do some internet search and see what I can find out.
http://www.customdynamics.com/loadequalizer.htm
We have to do similar things for bikes. Suspect it's possible to find a car version of these things or you could adapt one to work. Makes me wish I did the led conversion last year like I wanted on the bike so I could try the module out on the XJ too. May be worth the try if anyone has one of these installed on a bike.
It's my understanding those also get pretty hot and will melt plastic... so it'd be important to not mount them to the plastic taillight housing or else it'll melt... but again, I'm not an electronics expert and that was one of the various internet posts I read about adding these resistors.
Interesting... I swapped out the LED blinkers for incandescent bulbs and that took care of my fast flashing issues, but I still get weird 'double' blinking in that my turn signals work as they should, but it also flashed my LED brake light on the opposite side ever so slightly... unless I have my parking lights on.
It would be nice to be able to just go ALL LED for their advantage in life, durability and brightness.
Do you have your 3rd Brake Light (top light) using an LED or did you leave the incandescent bulb in there? I replaced it w/an LED and wondering if that might be enough (if I swap it back to Inc) to make everything work right. I have no idea and don't like just throwing parts at a problem... but I'd do it if it would work.
Why don't you want an equalizer? They are designed for exactly this issue. Something needs to soak up the additional voltage. That's why using one incandescent helps. It's either that or a complete rewire of the circuit with 5v relays, I suspect. Never done it that way but I bet that's how the newer cars that come stock do it.
I believe the issue is more due to the fact that current can't go back through the ZEVO units. The system seems to act the same if the ZEVO is installed or no light at all is installed. Yes, the resistor would solve that. I might just do that.
