Big Red
- Roscoe, IL 61073
CRASH said:Tri-County gear has a 35 spline setup available for a 44 now. Both full float and semi, with an ARB.
If I was building a rear 44, that's the way I would go.
CRASH
You still have that XJ dana 44 right, or did you sell it? Are you planning on going with a Ford 9" soon, or is your 8.8 holding up o.k.? What is the weak link of the dana 44 with the 35 spline alloy shafts, and CTM or OX u-joints? What's the max tire size on a 35 spline 44, 37's? Should be able to run those without too much concern.
