funvtec
- oak creek, WI
ok heres what i got going on
90 4.0 4x4
oil leaks all over
#1 needed a new pcv tube installed ( didn't have 1 when i bought it) fixed
#2 the valve cover started to leak then
#3 changed valve cover gasket, fixed the leak
#4 front breather tube was leaking, replaced with a small filter, fixed
then it was fine for about a week until all of a sudden when i park the jeep i get puddles the size of texas under the back of the engine, so i searched as much as i could i even double checked the valve cover gasket its fine. I then degreased the engine really good because there was so much gunk everywhere i couldnt see where it was comng from.
so with the engine clean and dry it looks as if i have an oil leak coming from inbetween the inspection cover and the engine does this mean i have a bad rear main ir a bad oil pan gasket
BTW auto zone brand engine cleaner works really well
90 4.0 4x4
oil leaks all over
