jeepguy97
- clearfield, pa
My old Wrangler amongst many of its problems also had 0 psi of oil pressure at idle. I replaced the pump and mains with no luck. I then replaced rods, still no luck. I then figured it was the cam bearings and started running HD40 weight oil so the pressure stayed up. I sold that jeep at 116,000 miles in that condition. My buddy who now owns it is still driving it around at 200,500 miles with no work done to it. He runs 30 weight oil and the pressure hovers at 3 psi at idle. HE says he will worry when it makes noise..... :dunno: If I would have kept it the motor probably would've seized up...just luck I guess.
That said, being that you did have a coolant leak, I would say it is the cam bearings, however iof it is earing related why didn't the pressure stay up at least just a little with heavier oil? I would say that if you know the pump is good, put some heavy oil in it and maybe some STP and see if it helps at all. If it doesn't I don't see how bearings could be the problem unless they are completly gone......
