Im about ready to drive my new XJ off a frickin cliff!!
Let me begin by saying I have been reading the numerous threads regarding low oil pressure, and there seems to be a serious issue with 2000 - 2001 low milage 4.0L XJ's that should have been addressed by DC long ago. I cannot determine wheter or not these camplaints regarding the "oil pressure dropping to near zero at warm idle" issue are indeed all the result of bearing damage caused by subsequent coolant leakages into the crankcase from a cracked/defective 0331 head. Out of the 5 - 6 cases of this I have seen posted here, the original poster never followed up with a solution or a diagnosis at that. I would seriously like to put this issue to bed because I'm guesing there are several others out there like me who want an answer.
That said, let me say that I recently bought a 2000 4.0L XJ w/ just under 50k miles. Driving around the first week I noticed the check gauges indicator lighting up at a warm idle, only to find my oil pressure burried at zero! Cold startup builds about 45psi. First though was the oil itself. I changed the oil with 5w30 and put in a new puralator and the problem persisted, so I swapped the sender with the same results. Crosschecked new sender with my mechanical gage simultaniuosly and the results were identical. Now I knew I had some serious problems. Pulled the oil pan, inspected the oil pump cover for excesive clearance - looked like it had been replaced recently. The shaft also engaged properly with the cam gear. Replaced the entire pump anyway cause I got one cheap. I dropped the mains and rod bearings next. Main bottoms .001 undersize/tops std.size both with little to no wear. plastigaged them all at .0015" oil clearance. The rod bearings were a bit worn: tops .001/bot. std size - is this a factory practice? raplaced rod bearings for shats and giggles with .001top/.001bot. - plastigaged at .0015. While under the lift I noticed quite a bit of water in the oil dripping down from the block. Searched the forum then came across the 0331 cracked head posts. Sure enough, between 3 and 4 exhaust ports was a gaping crack leaking coolant! wow what crap all in the first week of ownership!
So I replaced the head with a reman 0331 cast (why i chose to go with another 0331, I dont know!) Ironicly I noticed it was welded/reground in the exact same spot my old one had cracked! I was a bit hesitant about putting the new one back in, but the one year warantee gave me a bit of confidence....
Sunday I finished up and fired it up with no problems. Purred like a pussycat! Ran it at idle for 20 minutes then took it for a spin. Would you believe I have the exact same pressure problems - ~0 pounds at idle, <20 at 1600rpm with awful lifter noise - like as if i didn't "fix" a damn thing! Rechecked the new head for the crack and it looked like it was holding. I drove it it all sunday then today, dumped the oil and didnt detect any water but oil seemed a bit thin. Replaced oil with 20w50 and same thing! I haven't overheated it since I've had it, with coolant temps never exceeding ~205F.
So now my dilemma...where is the pressure (or should I say oil) going? severely worn cam bearings? Cracked block? What about the lifters? When I had the head off, I pulled all the lifters, inspected, cleaned and reprimed them. All were slightly worn (crown on camshaft mating surface were CONCAVE to about .001" - seen lifters much worse! I'm confident I did the bearings right because ive done probably 10 of these jobs before, although performed on engines removed from the vehicle. You would think pressure decreasing with coolant temp would be indicative of bad bearings - I'm at a complete loss.
Please, help me with your experiences. I am seriuously considering a complete rebuild at this point! Any info would just be great. BTW, i bought this vehicle at an auction with the assistance of a dealer friend who passed his wholesale savings on to me, so I can't really hold him resposible for repair costs. Well, i guess I could at the expense of the loss of a friend!
Thnks,
Eric from upstate NY
ps - things i havent done but I am considering:
compression test, but I have *plenty* of power
leakdown
coolant pressure loss
pulled the motor - next?
Thnks,
leakdown
