96 pump is on front and as mentioned, it can be changed without dropping the tank.
Be sure there is less than 1/4 tank of gas in tank. Do NOT force it, and try to remember how you turn the pump as the new one is the reverse going in. The rubber peg on bottom of the assembly goes into a hole inside the tank, and this lets the mounting flange sit flat on the tank. If not in hole flange has gap on one side.
Get a new "o" ring ($7 or so) that seals the mounting flange and vasoline it during install, take locking ring down slow while watching o ring to be sure it stays in the groove. Use a popsicle stick or the like, to push it back in to groove if it pushes out.
Be extra carefull while working around fuel and do raise the rear of Jeep for access. Extra well blocked and on stands.
Good Luck,
Orange
Good Luck,
Orange
