FiveNdime
- Washington
The stiffness isnt the cause of the set screw on top being to tight as that would effect the whole range of steering. This is a valving issue, for sure. Its an easy mistake to make while building it if you get the large adjustment nut to far one way or the other it will cause stiff/high resistance while steering in a certain direction. I have another box sitting on the shop floor right now so once i get that in I will be either singing praise, or very unhappy. I will post up tonight if I get it in. Thanks for the help.
