Matthew Currie
NAXJA Member #760
- Vermont, land of big clay
If you look at the pitman arm and the shaft on the gear, you'll see that the splines don't go all around - there's a keyed area with no splines. And that nut holds the pitman arm down pretty tight too. I seem to recall that it's tapered. I think it would be almost impossible to slip a spline. You'd break something first. It's more likely something somewhere is bent.
edit : Kleak notes :
Yes for a Saginaw recirc. ball steering - I think almost anything else would break first, but it's not quite so uncommon with worm and sector gears such as those found on tractors, and I've heard of it on the old worm and peg boxes VW used to use. Not much to fall back on there.
To break the insides of a steering box would be the first time I have ever heard of it....
