How to flush out your brakes:
If you want to do it in the morning, coffee CAN be substitued, not for the brakefluid, only the beer.
€Here's the best way to bleed 'em from an old post.
I'll just copy and paste mine from an earlier thread, but this is for an evening bleed, not a morning one.
"I did em that way for MANY years too. Called the kids or the old lady out and told em "pump it up and hold it down", and opened up the bleeder until the pedal went way down. There is a way easier way, but it takes longer. I use it whenever I replace brake cylinders or calipers, but mostly it's just to change the brake fluid, which I do whenever I change shoes or pads. Ideally you change brake fluid at least every other year. If you worked on old cars and saw rusty pistons, you'd know why, but people also say that old brake fluid boils and won't stop you right.
The best way is the GRAVITY method. The only problem is it takes a lot of beer and you don't want to drive right after. (CAUTION: YOU MUST BE 21 TO BLEED YOUR BRAKES THIS WAY!)
1.) Get the car in a position where you can open up the bleeders. I always like to break them loose with a 6 point socket being careful not to break them off. If you can, spray them with breakaway or similar a day before.)
2) Starting with the bleeder futhest away from the master (pass. rear), open it about 1 turn. You can put a little hose and cup on it if you want to keep the old fluid from running all over. Make SURE to keep the master cylinder topped off with fluid and DON'T let it get down to where air gets back into the master cyl. Let it flow this way until the fluid comes out of the bleeder clean. This will take at least 2 cups or so of brake fluid. Using gravity alone, you can drink 2 beers while topping off the master cylinder for the first corner. (CAUTION: Do not store brake fluid in beer cans or put beer into master cyinder. Drinking a little brake fluid however will probably not kill you. Beer in your brake lines might.) Snug up bleeder good when you're done.
3.) Proceed to drivers rear and repeat. It won't take as long because the long brake line has already been purged of the old fluid. So you have to drink your beer faster.
4.) Pass front. Drink even faster.
5.) Drivers front. Etc.
Patience can be substituted for beers, but that's no fun.
This prevents the rubber pieces from going any further than they are used to and self destructing.
:cheers: "
