ipkyss
- Hampden, MA
Just had a thought here. I have a 98 xj with 35s. After a lot of wheeling at higher rpm, snow, sand, mud, ect. The power steering starts to over heat and get noisy. I figured on just adding a cooler in the return line. More fluid/ capacity and better cooling at the same time. Then I had an idea. Sense I have a 5-speed, I am not using the factory trans cooler in the radiator. I just replaced the radiator with a 3 core. Is there any reason I should not use the trans cooler for my steering? Anyone try it yet?
