muddymopar
- Boise, IDAHO
So I took apart my steering column a while ago and it does seem right anymore, The actual steering column does move however the wheel and little shaft inside move around...i.e. you can grab wheel and move it up and down and side to side inside the column...so i was thinking about changing the whole thing out for a new used one... how much work is involved in that...any wiring issues i might come up with if i didnt get the same year as mine? it is a 90 with a tilt wheel and its automatic...so do i have to find one out of a rig with that same set up? or would that matter other than if i wanted tilt wheel or not....
its still drivable but it makes it a real pain in the A$$ to drive around on the highways...
any help guys?
Thanks ahead of time
any help guys?
