MT Mike
- Helena, MT
What Joe said, but this is from the JCR bumper install Instructions-
Problems
Occasionally you will find a hole on your frame rail is slightly different than a hole in the bumper or tie-in
brackets. Many times this is very minor and easily solved. Line up all holes that fit and temporarily install those
bolts. Take a drill bit just bigger than the bolt size intended for the offending hole and run it through the tie-in
and the uni-frame.
This may apply to the spacer.
I actually tried that, but snapped the biggest bit I had trying to open it up. That's the point when I decided to use the OEM one I had. I've sent an email to JCR to see if they'll swap a good one with me. I'm sure they'll make it right.
Believe me I tried. The holes on their spacer would not line up with the OEM spacer. I tried drilling it out, but snapped my biggest bit in half. If JCR won't exchange it, then I'll try opening it up more with a different bit. If that doesn't work, I'll just throw the damn thing in the trash and buy one from C-Rok. No big deal either way.
Bottom line is, with any company's spacer, check it against your OEM spacer (if it's in one piece) before spending hours on your back cussing at the damn thing.
