dishner
- North Carolina
This is my first post on here. I have been looking through the forums and have found alot of useful info but I'm now at a stand still.
My 98 decided it didn't want to start anymore yesterday. Turn the key, everything has power, lights, radio,etc; but no start. I can hear something clicking, sounds like it's coming from the glovebox, which I assume is a relay of some sort. I jumped the starter off with a screwdriver and it started fine so I know it's not that. Also replaced the ignition switch, same thing.
Right now I'm leaning toward starter relay, but I actually can't figure out which one is the relay for the starter (I'm guessing it's located in the black bow under the hood on the passenger side) If anyone could help me figure out which one it is I would appreciate it.
The other thing I am very curious about and can't seem to find any info on is the switch in the clutch that allows it to start. Mine is a manual and I know there is a switch in the clutch that won't let you start the jeep without the pedal depressed. I am assuming this switch must be located in the tranny itself since I can't find it in the cab.
Sorry for the book. Thanks in advance for all the help.
