Lowrange2
- Abbeville, SC
So, I'll do my best to describe this issue. Read closely.
I've had zero problems with my starter in the past.
93 Sport 4.0 auto
I'll make a video if it helps.
Yesterday my water pump went out. I towed it back home and replaced the water pump. When I started the engine to back it off the trailer the starter makes the same sound a starter will make when you try to start it while it's already running.
It turns over and starts fine but makes the grinding noise for a split second in the process of doing so.
Turn the key on, turn key to the start position, the engine spins over just as it should with no sounds. From the time it takes my brain to register that the engine has started to the time it takes for me to let go of the key it makes this sound. It makes this sound for maybe half a second. If I turn the key to the start position again while it's running it makes the exact same sound, obviously. Once I let go of the key it no longer makes this sound and runs perfectly fine.
My first thought was that the bendix were bad in the starter so I replaced the starter. Same issue. Exact same symptoms.
I've had people tell me that the ignition switch is sticking but I'm certain that's not the case. It springs back quickly and stops making the sound as soon as I let go.
A starter shouldn't work that way. Once the engine starts spinning faster than the starter, the bendix should retract from the flex plate immediately via the reverse threads in the bendix. For what ever reason it's not doing that.
WHY!?
Everyone else I've talked to about it says to just get used to the sound. That's not happening.
Grrr!
Thanks, Andy
93 Sport 4.0 auto
WHY!?
Grrr!
Thanks, Andy
