Stalls in drive
Cubbetm
Indiana
96 cherokee sport 4.0 automatic
Starts and idles fine in park, reverse, and neutral, but when you put it in any forward gear the engine bogs out and stalls. You have to put your foot down to get it to start like it's flooded.
I'm assuming TC is locked up. Any other ideas?
Side note. It was after I had to limp it home in 4 high with no rear shaft. It does have the 231 case and I've done it plenty times before
Second side note. The blower doesn't work. Happened at the same time now that I think about it. Last time I took it out is was real rainy.
Just in case anyone is curious if if unplug the tcm it doesn't stall. TC is definitely getting signal to lock up. I have a good known module at work. Will update Friday
