- Columbus, In
That comanche Is SWEEEEEEEEET! man. I like seeing a Jeep fly down the road then suddenly slamming on the brakes to whip it around a corner!
I was talking about the single tube 7100s, not the remote reservoir shocks. The pricing I've looked at have the 7100s in the 130-150 range and the 5150s around 100-110. (yep, the RR 7100s are 190-200 )Not a lot more expensive = twice as much? Is it really worth double?
Yep, stock brakes. :shocked: I think he's got Mopar pads(he's a dealer mechanic) I should mention that we've had brake failures twice now due to the fluid splashing out the top. 'Can't seem to keep the cover sealed when the truck gets bouncing hard....,Stock brakes? What do you run for shoes?
We run engine temp, oil pressure, and voltmeter. He has a big-a** tach on his side.We definitely need a full array of gauges, since all I have is a shift light (no tach).
I'll get with Derrick this weekend and see what info he's got on the springs. That fuel cell was in the truck when he bought it. We have a spare that we got off Ebay for about $450.00. I like the idea of a fuel cell, but if your rules don't require it, you might want to spend money elsewhere first.I'd be interested to know your spring rates. And I would kill for a 32 gallon tank....
I was kinda thinking 2.8 litre block. 3.4 rotating assy, milled heads to up the compression - I know Comp Cams lists some cams for these. Some headers and maybe a Holly 4412 if rules allow...Gotta build pretty good power, I would think? Almost 1.0 litre bigger, and would be pretty hard to detect unless they pulled the entire motor apart...IIRC, the power output of that v6 was pretty blah, and compared with the 2.5L, so I don't think it would be worth the time/money for the swap. If anyone has a better opinion, feel free to share.
I saw this, but do they do engine tear downs to check for this ? Its only cheating if you get caught - Ask Smokey Unick...LOLOnly problem is the class limits me to 3 liters max.
Find a longer pitman arm then the one you are currently running. Chrysler did that with the 'Cuda/Challenger in '70 from the factory. The "quick ratio" steering consisted of a different pitman arm.If I wanted to quicken up the steering ratio a little, is there a simple trick for that?
