Here is the thing about the O2 sensor offset funcion in the F/IC. It has been tried, by several folk here on the board, without any level of success which is why I abandoned the E85 project. Do a search and you will find the threads. The Stroker Guys have been attempting to get it to work and not even AEM can explain why it doesn't except for the normal "Well it is a Chrysler product" disclaimer. Out PCMs are not very user friendly.
Enrichment under acceleration. As the F/IC reads the injector pulse sent by the PCM and operates the extra injector per the table. What this means is, if the PCM is calling for a longer duration pulse width, the AEM will use that width as part of the calculation. My suggestion, to those interested. is to download the dcumentation and read it.
Under WOT, the PCM goes open loop. I have mine adjusted to hold mostly mid 13 AFRs in these conditions. IMO, into the 12s is a tad fat. That being said, I have a couple of points that drop down to an AFR of 12.9.
Installation and wiring of the F/IC. I installed my F/IC right above the brake booster (made a sheet metal bracket for it to sit on) and cut into the harness at the inner fender line approximately 1' away from the firewall as it made it easy to sit and solder the wiring... It is just cut into the factory harness and wire in the new. I used cable covers to match the factory wiring. If one is not completely comfortable with doing the wiring, do not attempt it, find help.
There isn't a pre-made harness anymore. Only two were ever made and I built them both. One was put into the Boostec XJ and the other went to South America. Plus, the two in question were for the Perfect Power SMT8-L controller, not the AEM F/IC. Even my initial installation (SMT8-L) had me cutting into the factory harness and I was still associated with Boostec at that time.
It was as a reward for pointing out the wiring solution to Sprintex that I obtained my kit. Sprintex, gobally, was having issues with folks screwing up the wiring and then attempting to blame Sprintex for thier failure. I solved a problem for them. As a Process Engineer, it is what I do. Or did, anyway, for a living. Plus, I do provide feedback to Sprintex on the performance of the system. Legally, Sprintex holds title on thier parts in my Heep. I do not own it.
AEM had to discontinue the 96-04 ECM Extension Harness from thier catalog due to the manufacturer of the PCM side connector (the single large one) discontinuing production due to lack of orders. The Extension Harness has been out of production for over a year.
CobraMarty, you will see 7lbs and you may see 8lbs of boost as you are near/at sea level. I get 6lbs here where the air is a tad thinner... Providing, of course, that the engine is in good nick to begin with.
Just an FYI on fusing Aluminium. Aluminium was being welded together long before MIG/TIG welders had been invented by using a brazing process. Take the aluminium up to 720F with an Oxy/Acetelene Torch and apply the rod to it. Permanent bonds are achieved.
