outlander
- Columbus,Ohio
I have solid covers on my d30 and cryco 8.25 and when I first installed the cov ers I added lube untill it was up to the bottom of the hole just like you would on stock covers.A few months later I noticed my driver side axle seal is leaking.Related???Did I over fill?
Where should the level be....at the bottom of the hole or should you add however much the capacity chart calls for and is there any risk of blowing axle seals by over filling due to the solid covers hole being higher than a stock cover??This question has probably been covered before so dont Hasta me too hard
