either upgrade to h-4 conversion or(by the way it sounds that you havent looked at them), check em out and see if you have a head light out, i mean c'mon are you too stuborn to look at them and see what the problem is or do they really suck that bad? if they really suck that bad try to adjust them, stock ones work fine if they re adjusted ok, h-4 make it even better if adjusted properly, just think of it as if you were looking at the world cross eyed, if your head lights are cross eyed, then everything looks f'ed up,go get glasses and it fixes the problem, apply it to your rig, go get the lights alligned, or allign the lights your self, and tah'dah..... im not rying to be an ass hole, im just putting in my 2 cents, dont say "i havent even looked at them" and not expect to get laid into for not doing so! c'mon now use your head!!!! all in all make sure you have both head lights, then make sure they both point where they are supposed to. if they still suck then upgrade!
