My Drivers side window appears to have a 'catch' when going up or down. Sometimes it will go up and down easy and smooth but most of the time it drags and sometimes hangs up all together for a second or two before continuing either way.
I've read thru a few 'how-tos' on ways to fix this so this weekend I pulled the door apart. Using White Lithium grease I lubed the tracks fore/aft where the window rides, lubed the center metal 'carrier' front/back that the window rides on and made sure the electrical connection was good and clean and put some dielectric grease on it. I wasn't able to lube the area that where the motor spins the track (the screw drive area if you know what I'm talking about). Worked that lithium grease in good, up down up down... and the window worked pretty good. This morning it was back to it's usual super slow movement.
Does anyone have any ideas what could help? I hate to replace the entire power window regulator w/motor if that's not necessary. I mean mine still works, but it's VERY slow.
Any other ideas or suggestions would be appreciated.
