everybody makes mistakes
heck if you can just get like a 8 degree shim and that would be a lot cheaper than an sye and that might solve the pinion angle.
You can do an SYE for a hell of a lot less than 500. At least, if you don't mind a hack n tap...
$90 for yoke+shipping from drive-line.com
$15 for 3/8-16 or 1/2-13 drill+tap from Lowes
$5 for grade-8 washer and bolt of same size and thread pitch
$40 for lift fee + front driveshaft at you-pull-it
however much for shims, or reweld perches
I come up with $150. I actually spent a good deal more than this as I picked up a spare front driveshaft as well and a full tap&die set instead of just the tap I needed, but that was just me...
the difference between stock and 33' is about a 20%
so 150 miles would be 180.
20% of 150 is 30, so 150 plus 30 equals 180.
wow
No.dont mean to thread jack, but to do a hack n tap couldnt you use the yoke off of your old rear drive shaft, make the cuts, bolt it down, the put bolts in from the front side of the yoke that thread into the drive shaft... dont remember exactly wut it all looked like ha
