XJ Dreamin'
- Huntsville, Texas
Hey All..
I'm late into a well established thread but I''ve enjoyed following along and finally can't resist.
I grew up with gravel and tarred gravel roads: what they call down here in SE Texas "chip seal." Today I have access to guite a lot of well maintained gravel with ALOT of trees whippin' by the window.
When I was learning how to drive my Dad had two rules: "Do It Right!", and "You break it, you fix it!" A kid doesn't care about danger but the thought of spending weekends or vacation time trying to straighten out a car, or rebuild a motor would slow you down real quick.
What he taught me on gravel was this:
a) Get your braking done before the start of the curve - you can't break and steer at the same time;
b) Initiate the turn at the beginning of the radius with a slight flick of the wheel into the curve;
c) apply throttle to bring the rear end out (oversteer);
d) compensate for the oversteer but steer the line through the curve - the goal is to align the front wheels with the exit of the turn by the time you reach the exit: forget the "steer into/out of a skid" nonsense: point the front wheels where you want the rig to go and use the throttle to control the rear end.
e) done properly, by the time the the vehicle reaches the exit of the curve the front wheels and the vehicle centerline should be lined up with the road. By that time you should be using nearly full throttle.
DISCLAIMER: Remember, this isn't me, a noobie non-member, telling you what to do. I'm only saying what my Dad taught me.
In a nutshell: after braking, the throttle is used with the initial steering flick to the inside to start the rearend out. Combined with the initial steering flick to the inside it shouldn't take much throttle to start the rear end out. As the rear end swings out the line of the front end through the curve is controlled by steering while the extent of the swing of the rear is controlled by the throttle. Ideally, as you approach the exit of the curve the front and rear come smoothly into alignment with the exit. The closer the front and rear are aligned, the more throttle you can feed in. If you exit the turn with the rear end swung out you only waste time fishtailing trying to get it straightened out. If you exit in alignment with the road you can feed in as much throttle as needed for max acceleration.
Control the line through the turn with steering. Control the swing of the rear with the throttle. Of course, the two are connected by the rest of the car so it is a constant, delicate dance to get through on the optimum line, in the best time, with the greatest exit speed possible. That's the fun part.
The trip I took through the soybean field in Dad's '72 Grand Fury was not the fun part :doh:< me - Dad > :nono:
